Carbonfiber ring
44 opens
4 copies
HemiStorm RC - Chris de Graaf
Halden, Norway
Here is an easy to create ring made from 2mm carbon sheeting. In order to permanently fuse the pieces together use some CA glue to stick them together, and wet sand the edges to ensure a comfortable fit. Inner diameter is set at 18.5mm, and can be modified to Your own size.
