Camaro Parking (for Dad)
60 opens
25 copies
Jenna Richards
Jenna Richards
Chicago
This project is a Two-Stage Carve with an outline that is a separate workpiece. It is carved after completing your Two-Stage Carve.
You’ll also see the use of raised lettering combined with V Carving.
The first iteration was plywood. For quality, I downsized the design to fit on 2 color HDPE.
Birch Plywood
Birch Plywood
Carbide Tip V-Bit 60 Degree - 1/4 in Cutting x 1/8 in Shank
Cutting Diameter: 1/4 in, Tip Angle: 60 Degree, Shank diameter: 1/8 in
Two-Color HDPE - Black on White
Thickness: 1/4 in, Dimensions: 8 in × 12 in
