A sweet little bunny, suitable for general cuteness, Valentines day, or Easter. The piece pictured is made of 3/4 inch Poplar using standard MDF settings. The standard bit we use is a 1/8th inch, but when measured exactly, it is .123 inches, so the easel file reflects that with a custom bit.
No Derivative Works — You may not alter, transform, or build upon this work.
The author’s moral rights;
