A detailed video tutorial of the steps for designing and building and Illuminated Sign
(This Tutorial uses Adobe Illustrator, but the process is similar in other vector drawing programs.)
Start with an outline of the the text you are going to make into your sign. Scale it to a the size you want the illuminated text of you sign to be.
Use the Path – Offset Path tool to Offset the outsides of the letters 8mm, This offset is going to be the outer edge of your sign
Move the original letter outlines to a new layer and lock them.
From the ‘Windows’ menu, open the pathfinder tool. With the outlines selected, Click ‘Unite’ to trim away the overlaps and make a single outline.
Tip: Give your sign a cleaner outer edge by straightening its outer profile.
Create the signs back by copying the outer outline of the front face and move it down to create a new part. Add a hole for the LED’s power cord.
To make the sign’s fill layers copy the outline of the back and use the offset tool to offset the line inwards by 8mm. You may have to set the Joint Style in the Offset Tool to ‘Round’ to give these wall a consistent thickness.
Copy this fill layer two more times to create the three layers we need.
The Third fill layer needs to have a pocket to hold the sign’s colored acrylic lense. We’ll create this pocket by offsetting the inner line of the profile outward by 4mm. We’ll carve along the inside of this line with a 1/8th inch mill bit at a depth of 1/4 inch to create the pocket.
Save your sign’s parts as an SVG file and import them into Easel. Position the cut file so it’s not right up against any of the materials edges and set to set your material type, size, and thickness.
All of the cuts except the pocket need to go all the way through the material, so the depth needs to be set to the thickness of your material. Remember to check the ‘Use Tabs’ box, so the parts won’t break loose and fly away during cutting.
For the Pocket, we’re going to set the bit to cut on the Inside of the line at a depth of ¼ of an inch. This will create a pocket that can hold up to two layers of 1/8th inch acrylic.
To create the sign’s colored acrylic parts, copy and paste the line we created earlier for the sign’s pocket.
Offset this line inward half a mm and delete the original line. The offset gives the Acrylic an allowance around its edges so it can fit easily into the pocket.
Cutting Acrylic takes time. Make sure to use a single flute bit, set the correct material in easel, and clamp everything securely.
Tip: Some colors of acrylic are only available as transparent materials, which will let you see the hot spots of the LEDs inside the sign. For these colors, add a second layer of translucent white acrylic behind the colored layer to diffuse the light.
Assemble the sign by stacking the layers. Start with the back layer, followed by the three depth layers. the layer with the carved pocket needs to be on the top. Attach the layers together with glue or finishing nails.
Install the LED’s at the around the bottom interior of the sign and put the colored acrylic lense into its pocket. Attached the front lense over the acrylic.
Tip: For interior parts of letters, like the insides of the B or e, Use high bond double sided tape or epoxy to attach the MDF part to the acrylic.
Brian Gidney
Michael Curry
Frank Graffagnino
Michael Curry
James Steinbrecher
Chris Baber
Mike Plummer
Michael Curry
Matt Haas
Ryan Parish
Michael Curry
WorkinWoods
Ryan Parish
Randy Honeycutt
Kelly Shimabukuro
