Special Offer: Up to 17% off the new X-Carve Pro
Hurry! Offer ends on 05/28 (20 days left)
Call us: (312) 775-7009
Email: help@inventables.com
Bamboo Desk Organizer
Samantha Alaimo
Samantha Alaimo from Inventables
Chicago
The Bamboo Desk Set consists of six pieces that give you the freedom to organize your desk anyway you want.
Bamboo Plywood
Bamboo Plywood
Thickness: 3/4 in, Plies: 3, Dimensions: 8 in × 12 in
File type blank
deskset_01.svg
The first set of three
File type blank
deskset_02.svg
The second set of three
Generate Tool Paths
Download both the files. I generated the tool paths in Makercam. The instructions are in the video below. You can also use other CAM programs to generate your tool paths.
Cut and Secure Material
My Shapeoko set up uses the “hold down table” project. You can also screw the material into the waste board with wood screws.
Home the spindle
Jog or manually bring the spindle to the appropriate origin point. The file is set up with the origin in the lower left corner of your material.
Run the Gcode
I used Universal G code sender. There are several free g code programs recommended at shapeoko.com/forum. Once your Shapeoko is connected, zero your axis and upload the file. your file should be ready to run!
Finishing
I used an 1/8 in chisel and rubber mallet, to knock the tabs off of my piece. Then I lightly sanded the edges with 220 sand paper.
