45 minutes
After cutting the spider out, lightly sand and apply whatever finish you want(I used some spray poly). Then use some super glue along the inside of each hold to secure the bearings in. After that, I used a chisel to round off the corners so they aren’t quite so rough on the fingers when spinning it
