I have designed a 1.5mm wrap around bamboo case for the Amazon Echo 2,
The circles coordinates and radius are randomly generated from an excel
spreadsheet I have built. Therefore every case is unique.
This concept can be applied to any size project, table top, chair base, dinner tray…
The author’s moral rights;
