Alpha Sigma Phi CNC+3D
Charles Modrich
Charles Modrich
The machine is basically the Shapoko kit with added extruder and heatbed to create a 2-in-1 additive and subtractive rapid prototyper.
Aluminum GT2 Pulley - 20 Teeth, Dual Flange - 20 mm Pitch
Aluminum GT2 Pulley - 20 Teeth, Dual Flange - 20 mm Pitch (×3)
Bore: 5 mm - 2013 - 2019, Belt Width: 6 mm
Black Expandable Sleeving
Black Expandable Sleeving (×10)
Type: Expandable Sleeving, Color: Black, Range: 1/4 in - 3/4 in, Size: 1/2 in
$19.90
Mechanical kit (requires you provide electronics, pulleys, belts, and M3 hardware to function)
$300.00
DeWalt DW660 Spindle Mount
New Property: Spindle Mount, Type: Spindle Mount
E-Stop Button
E-Stop Button
Type: Latching pushbutton
Flat Washer
Flat Washer (×2)
Finish: Zinc Plated, Dimensions: I.D: 3.2mm; O.D: 7mm, Quantity: 10
$4.00
GT2 Belting - Open Ended - 4 Meters
GT2 Belting - Open Ended - 4 Meters (×6)
Width: 6.35mm - don't use, Pitch: 2mm - don't use
Hex Nuts
Hex Nuts
Height: 2.4mm, Pitch: 0.5mm, Quantity: 10, Width: 5.5mm, Thread Width: M3
Knurled Aluminum Knob
With crank
Microswitch
Microswitch (×3)
Type: Microswitch
$7.50
Silver PLA 3D Printer Filament
Type: Filament, Diameter: 1.75 mm, Material: PLA, Color: Silver, Shade: Silver, Spool Weight: 1 kg, 3D Printer Compatibility: RepRap
Length: 12mm - 2012 - 2018, Quantity: 10, Thread Size: M3
Socket Head Cap Screw - Packs of 10 each (×2)
Length: 8mm - 2012 - 2019, Quantity: 10, Thread Size: M3
Stepper Motor - NEMA 17
Stepper Motor - NEMA 17 (×4)
Lead Time: In stock, Holding Torque: 62 oz/in
Stepper Motor Cable
Stepper Motor Cable (×15)
Length: 1 ft, Category: Accessory, Type: Cable
Tamiya Power Connectors
Tamiya Power Connectors (×3)
Type: Power Conector, Material: Nylon, natural color
Terminal Block
Terminal Block (×4)
Positions: Terminal Block 4
$19.96
Waste Board with Threaded Inserts
Size (approx): 500mm 500mm 1/2" MDF, Inserts: M5 Qty 36
$351.36
ASPCNC3D-Slic3rSettings.ini
These are the slicing settings that I use that seem to give the best results.
ASP CNC Bill of Materials - Sheet1.csv
True bill of materials for this project including parts sourced from outside of Inventables
Randy Buster
Charles - I am about to kick off a project much like what you have done. Are you willing to discuss what logic boards you are using and what it takes to switch from CNC to 3D??
Randy Buster
Charles Modrich
Of course, the electronics I used was an arduino mega 2560 with a Ramps 1.4 electronics board. These should be reflected in the bill of materials document (.csv) under the digital files section. If you have any other questions feel free to ask!
Charles Modrich
Gregg Harrington
Did you build your own extruder or buy a turn key design?
Gregg Harrington
Charles Modrich
This is the Extruder that I used: http://tinyurl.com/nbpmznf Would not recommend that one again though, it clogs way too much for my liking. I did have to make my own fan setup though, I created a fan shroud to attach a dc cooling fan aimed at the print surface.
Charles Modrich
