5 Panel Bench
126 opens
64 copies
1 comment
Paul J. Bennett
Paul J. Bennett
Milbridge, US
This 5 Panel Bench was specifically designed to fit in my Inventables X-Carve 1000mm, CNC router. It was also designed within the Easel software that drives the CNC machine. I built the bench for a non-profit fund raiser and posted a YouTube video of the build.
5 Panel Bench Assembly - Drill Pocket Holes
After cutting out parts on the 1000mm X-Carve and cleaning them up, drill all the pocket holes as shown in the video. Please note the stretchers file is located at the bottom of the Easel page by clicking on the link that says "Workpieces for DTC 5 Panel Bench.
You will need two pieces of plywood.One is 31″ × 31″ for the top and legs. The second (for the stretchers) is 28″ × 16″
5 Panel Bench Assembly - Assemble with Pocket Screws
Position parts and fasten with Kreg 1-1/4" course, pocket screws as shown in the video.
5 Panel Bench Assembly - Finishing
Sand bench down to 220 grit sandpaper, and apply finish of your choice. You may paint, stain, varnish, etc. as you choose.
Paul J. Bennett
I was able to correct the errors previously reported to me. When you open the file in Easel, you will find the stetchers for he bench in the "Workpieces" section (hyperlink) at the lower left hand corner of the page.
Paul J. Bennett
