1800 MM X-Carve Upgrade
35 opens
12 copies
4 comments
Kris Crawford
Kris Crawford
Canada
About a year ago I purchased parts from Inventables to upgrade my 1000mm x 1000mm X-Carve and transform it into a mammoth 1800mm x 1000mm machine, which I’ve nicknamed the siX-Carve, as it’s just under six feet long.
https://youtu.be/OlThn7nHksM
Aluminum Extrusion (20mm x 40mm) - Clear
Aluminum Extrusion (20mm x 40mm) - Clear (×2)
Length: 1800 mm
$56.00
Button Head Cap Screw
Button Head Cap Screw (×4)
Length: 8mm, Pitch: 0.8mm, Quantity: 10, Thread Size: M5
$9.96
Length: 10mm, Pitch: 0.8mm, Quantity: 10, Thread Size: M5
$2.99
Extrusion Bracket (Gusset)
Finish: Clear Anodized, Quantity: 4
$1.50
GT2 Belting - Open Ended
Width: 6.35mm, Pitch: 2mm, Length: 4 meters
$20.00
MakerSlide
MakerSlide (×2)
Length: 1800mm, Color: Clear Anodized, Ends: Not Tapped
Pre-Assembly T-Slot Nuts
Pre-Assembly T-Slot Nuts (×4)
Thread Size: M5 (5mm) × 0.8, Quantity: 10
$20.00
X-Carve Drag Chain Kit
Desciption: 2 drag chains + supports and mounting hardware, Machine Size: 500 mm
$46.00
$156.45
Andrew Minter
Would you by chance have any pictures of your machine after installing these? Or do you have any input on if they have caused any issue for you? I'm just trying to find out if there's any drawbacks to doing this upgrade before machining the parts. Any input would be helpful, thanks, Drew.
Andrew Minter
Kris Crawford
This allows more clearance for larger material. I'm in the process of upgrading to a Linear C beam, so I actually don't have pictures as of yet. The only drawback would be if you are using thinner materials, so you would have to put a sacrificial board on your wasteboard to boost up the height.
Kris Crawford
DAVID TOLETTI
Thank you for the video and info
DAVID TOLETTI
matt solomon
Hey this is super cool. I've been wanting to do this since I got mine but wasn't sure if it was possible. I want to make mine 10 feet actually. Do you forsee any issues with going even longer? thanks
matt solomon
