The author’s moral rights;
I used a third of a sheet of 0.25" 6061-T6 to cut the base of the waste board. tapped the holes 5/16-18 for hold downs, and mounting MDF at a later date.
James McDaniel
The Gantry was stiffened by cutting 3 pieces of 3/16" 6061-T6 aluminum and welding them into an I beam. I had to press the maker slide into the Gaps in the I beam.
James McDaniel
I replaced all of the motors with 262oz NEMA 23s. This required me to counter sink the two screws near the belt window. (see Photo)
James McDaniel
James McDaniel
James McDaniel
James McDaniel
