Master Workpiece Holding with the CNC Cam Clamp Down Combo
When precision matters, securing your workpiece is just as important as cutting it. The Cam Clamp Down Combo is the ultimate solution for makers using CNC machines like the X-Carve Pro CNC. Designed to provide superior hold and easy adjustments, this custom clamp setup helps prevent material shifts, ensuring clean, accurate cuts every time.
Why Use the Cam Clamp Down Combo?
CNC projects often require tight, reliable work-holding to achieve consistent results. This cam clamp system is designed for makers and woodworkers looking to streamline their workflow while maintaining stability. Here’s what makes it stand out:
Key Benefits:
  • Strong, Adjustable Grip – The cam design allows for quick tightening and release without the need for additional tools.
  • Prevents Material Shifts – Securely locks down your workpiece, reducing errors and waste.
  • Compatible with X-Carve & Other CNC Machines – Easily integrates into standard T-slot wasteboards or custom spoilboards.
  • Efficient Work Setup – Spend less time clamping and more time cutting with a tool-free, rapid setup.
How the Cam Clamp Down Combo Works
The Cam Clamp Down Combo consists of a series of CNC-machined clamp arms and cam locks that create pressure on your workpiece as they rotate. Unlike traditional clamps that require constant adjustments with wrenches or knobs, the cam mechanism makes locking and unlocking as simple as a quick twist.
Materials You Can Secure:
✔️ Wood (plywood, hardwood, MDF)
✔️ Acrylic & Plastics
✔️ Soft Metals (aluminum, brass)
✔️ Foam & Composite Materials
Perfect for CNC Beginners & Pros
Whether you’re running production jobs or fine-tuning one-off designs, this clamp system makes your CNC workflow more efficient. For beginners, it simplifies the work-holding process, while experienced users will appreciate the time saved on setup and repositioning.  Elevate your CNC capabilities with a reliable work-holding solution that helps you achieve flawless cuts, every time.
Back to blog
