Temperature-Sensitive Glass
Textured glass tiles that alter in color with changes in temperature.
Design a beautiful shower installation that will shift colors through water temperature changes.
Applications for Temperature-Sensitive Glass
Existing Use
Existing Use
A stunning entryway in home or business can make a notable first impression.
Existing Use
Create your own customized tiles to fit your design or application.
Details for Temperature-Sensitive Glass
What is this?
Color-changing dyes and additives have been offered in paper, plastic and textiles for some time, but this product takes the idea into a new area: glass tiles. Offered in a range of colors and sensitivities, the tiles change color based on ambient temperature, body temperature or water temperature – whatever they’re touching.
The textured glass surface layer protects and highlights the color-change film on the tile. The base color of the tile can match almost any color, and the temperature change point can be fit to the user’s environment and requirements. The dynamic color change begins at the selected activation temperature and shimmers through three phases, one with each 6 – 10° rise in temperature. Once the temperature peak is passed, the base color returns and remains the same until the temperature drops.
The tiles come in six standard lines; each is a different glass texture, and each offers the changing display in different color moods and ranges, all matched by complementary decos and liners. In bath/shower rooms and other areas, the tiles could form beautiful water temperature safety gauges or be a visual room temperature marker. But this technology has also been used in art pieces that transform with temperature changes: In one, a cityscape changes from a day to a night scene, complete with lights. The tiles can be used on floors, walls and counters — and, because they use glass that is 20 – 80% recycled, they’re a green product.
In a few sentences, what is it that is unique about this item for product developers?
This glass product is unique due to its ability to change color and or image through any kind of change in temperature. Examples are human touch, a change in ambient temperature, warm/cold water; anywhere a heat or cold source is present. In addition, it can be designed in any size/thickness of glass, color/colors, and multiple activation temperatures. The base color can also be color matched to virtually any color imaginable.
What are the primary disadvantages of the existing technologies that this is an alternative for?
Standard tiles don’t do anything! Our state of the art products breathes life into stagnant environments, while most all glass, art, and building materials just sit there. Introducing our technology, either by itself or blending with other materials, achieves aesthetics like nothing else in the world.
What industries is this item typically used in?
Currently our Temperature Sensitive Glass is used in Architectural Design ranging from small glass tiles to large architectural pieces. All of our glass is rated for floors, walls, and counters. We are also a “Green Product” and use 20 – 80% recycled glass.
Examples of products currently or formerly on the market that make use of this:
Last year we had the opportunity to work with Disney. Together we created unique glass tiles that are installed in the Mickey Mouse Penthouse at the Disneyland Hotel. When Disney’s guests take a shower, the warm water hits the glass, causing the tiles to bloom into color. As the glass tiles change color, silhouettes of Mickey Mouse appear around the perimeter of the shower.
What are some unusual or creative applications others have found for this item (or you have thought of)? What about some far-out ideas that might get people thinking about other possible uses?
Any building materials for commercial or residential, such as: tiles, glass blocks, lighting, glass vessels, shower curtains, architectural glass, countertops, tables, floors, medallions, ceilings, roof tiles, walls, doors, etc…
Appliances, coasters, hot plates, serving trays, placemats, pots and pans, cooking instruments, furniture, etc…
Blow dryers, curling irons, irons, hair straighteners, etc…
Art, sculpture, picture frames, Christmas ornaments, candle holders, etc…
Advertising, movie poster light boxes, signage for malls, unique designs for theme parks, etc…
Casino chips, dice, board games, children’s books, games and toys, etc…
Surfboards, skis, snowboards, wake boards, water skis, etc…
Inside hardware for cars, boats and airplanes, such as: vents, buttons, dash, gear shift, controls, etc…
Theatrical stage backgrounds, special effects for movie making, concerts, etc…
Any other points you feel strongly should be included:
It is patent pending and each piece is individually hand made. Our designs can be predetermined or completely customized to fit the client’s needs. All designs are original.
What is the temperature range for the tiles to change color?
All products are available in a variety of temperature ranges, allowing customization to your specific applications. The maximum temperature range for our “Liquid” line is -30°C (-22°F) to 120°C (248°F). Color change will begin at selected activation temperature, and continue through three phases within a 6-10° rise in temperature. Once past the peak in temperature, the base color will then return and remain unvarying until the temperature drops.
What size are the tiles?
All of our lines come on 4″×4″×3/8" thick glass tiles.
What colors are available?
We offer:
1. Tiles that appear black at room temperature and move through the color spectrum when temperature (warm water, radiant heat, etc) is applied.
2. The tiles shift from a base coat of color to colorless when exposed to heat.
3. Tiles that can transform to organic designs, decos, and images.
What is the price range for this material?
The standard color change tiles cost $33 each.
Back to top of page
Color changing glass tiles are 4" x 4" in liquid red.
$33.00 each
Interested in this product?
This vendor is currently accepting inquiries through Inventables.
Contact this Vendor →
My Visit History
Ajax LoaderLoading...
clear visit history
