Halloween Lamp
1090 opens
413 copies
5 comments
Jeff Parish
Jeff Parish
Kailua Kona, Hawaii
A unique Halloween Lantern with either LED lights or candles. A fun project using Easel to create that Halloween atmosphere and shed a little light on things.
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Material Type: Extruded
$4.99
MDF Wood
MDF Wood (×2)
$7.98
Add to Cart
$12.97
Cut outs
Cut out panels using 1/4" MDF with .125 bit.
Glue up
Glue panels (and bottom) using super glue. Coat with lacquer sanding sealer, light sand, spray primer, and paint.
Acrylic box
Cut panels (4 side) to fit inside lamp. Glue with IPS weld on #3 or you can use super glue as well.
Light
I used a led light for mine but you could use a candle if you prefer. (I think) Haven’t tested with candle. Don’t know if it would melt acrylic panels after time.
James Steinbrecher
I made this. Have a look at my video at: https://youtu.be/Ib75vfKuopk
James Steinbrecher
Jeff Parish
I'm glad you liked my project enough to make one for your self. Looks like yours turned out great and loved the YouTube video. Duplication is the highest form of flattery....Thank you. Jeff
Jeff Parish
Ranvir Jatana
Would you be adding the digital media files to this post?
Ranvir Jatana
Jeff Talbot
Hi Ranvir, you can open the design in Easel by clicking the "Open in Easel" button on the right side of the page above.
Jeff Talbot
David Croft
Great project. Made some tiny changes: younger son changed some of the silhouettes, added in a groove close to the bottom to hold the base. Used cellophane as windows. Added text to the base with kids name. Added holes for carrying handle. Son now painting outside. Trick or treat sweety box.
David Croft
